Originally Posted By: BuickGN
Has anyone actually proven that thicker oil increases startup wear? I see it here over and over but never any proof. I'm talking within reason, not using a straight 60 weight in -20F conditions. I see oil coming out of my rocker arms on the Buick with 20-50 the second the engine fires.
I know exactly what you're saying but it's not residual oil left in the pushrods and being flung out by the rockers. Flow is even from the get go. FWIW, this was done with the valvecover off.
Another thing I observed when I put a temporary oil pressure guage at the turbo feed (top of the engine) with a see through oil line is instant oil movement. If the thinner oil gets there faster, it would have to be measured in miliseconds.
It's the same with my Jeeps running SAE30 or 10W40. My 2.5L Wrangler trail heep starts to build pressure as I crank it over. It flows to the rockers immediately. The 355ci in my Malibu drag car does the same. They both have high volume Melling pumps though.
