Originally Posted By: SavagePatch
What are we considering long? A minute or two or until the idle rpm drops?
Does an engine warm faster with the heater set to cold and fan to off or with the heater set to hot and the fan on?
@Shannow: Are you saying that warming the engine unnecessary? Just curious...
...Thanks in advance!
The things that Merk wants to achieve are the reasons that the OEMs put in the fast cold isle in the first place.
The bearings turning at a couple thousand RPM pump create nearly 4 times as much frictional power as at 1,000 RPM (when talking bearings, think also the large surface area of the piston skirts as bearing surfaces).
See this diagramme
That particular engine/oil combo, from cold, 2,000 RPM was about 4KW of frictional heating of the oil (think in terms of putting 4KW of bar heaters under the sump)...at 1,000RPM, would probably only be 1KW. That 4KW of load also means that the Exhaust temperatures will light off the catalysts a lot sooner.
Seriously, we start the car, then belt up, then drive. In (my -5 to -11C) winters, holding the trans in "2" until I get out of town has a notable affect on the temp guarge.
So I firmly believe that getting the OP up, the engine stable in gear, and driving off are the best for all.
I'm not advocating what friend(s) used to do, a burnout from cold in the morning with 20W50, just light throttle, 2-2,500 RPM, and get the heat in there.
See this diagramme
