Yes I know. The new CK-4 is very low on zddp. Both of my tractors use flat taps on the cam. If you do a little research straight weight oils are still in use in locomotives and Marine engines. Engines that are under a high load consistently. Pulling a 10 ft bush hog loads my 100hp tractor up pretty good.Straight 30 is so obsolete. I know most say to follow the manual, but things have come a long ways too. I doubt you’re running these in the cold so I’ll spare you the finer details, but this stuff isn’t exactly easy to find either.
15w40 is the new straight 30. Has been since like 1987. $12 a gallon at your local Walmart.
