The best built oil filter in your opinion ?
Clovis, CA
What would you say is the best built oil filter that has zero chance of coming out with bent/wavy/torn pleats at the end of the OCI ? Assuming cost is no factor.
In spin on filters Fram Ultra or NAPA Platinum/Wix XP. Both of those have wire backed media, which should hold the pleats true.
In a cartridge filter, anything from Mann, Mahle or Hengst.
Just go get a Fram Ultra and save yourself all this repeated "research" hassle.
Hey, I'm drumming up stuff for us to talk about. You could call me a conversation machine.
...bent/wavy/torn pleats....
I can live with bent and wavy pleats, although I will admit I'd rather not see that. As for the torn pleats, that's something Purolator should be able to remedy in a hurry.
I don't think there's any filter out there was a zero chance of having something go wrong. In the end, I'll carry on with Wix, Motorcraft, Hastings, and Bosch (if I can find them again and when the torn pleat issue blows over).
I like the Fram Ultra and Mobil 1 filters. I was on a Purolator Pure One kick for a while but feel their quality has dropped off a bit. JMO
Originally Posted By: Joe_Power
I know Purolator is getting a bad rap, but I still think the P1 is one of the best filters for the money.
I agree but the issues are concerning.
Fram Ultra I was very impressed with and for the $.
However if you do not want to spend 8$ of a filter NAPA Silver was very impressive when I cut it open.
K&N I do not like.. Only way I would tell someone to get a K&N is if the oil filter is in a very hard place to get to and that built in NUT makes it easy to remove.
so FRAM ULTRA
or NAPA SILVER
Or even MOTORCRAFT
but #1 choice I have to say FRAM ULTRA
Originally Posted By: spasm3
I've moved from purolator to Mobil 1 filters.
Same here. PureOne's to Mobil 1 Extended Performance.
Do you feel the weight difference?? It's amazing!
