Tercel cooling system won't hold pressure
cincy
94 tercel. I decided to finally flush the coolant on my old beater. I drained the radiator and blocked and hooked up my airlift coolant refill tool. It sucked the system down to 26 pounds, but would never hold steady pressure, would creep down. I didn't see any external leaks. I had to replace piston rings about a year ago, so the head gasket was replaced. Seems to cool fine and no other issues besides not holding pressure. Any reasons why it won't hold?
Is that a vacuum exchange system? Maybe the hoses were collapsing?
I guess your next test is to (carefully) open the cap when it's warm to see if it makes any hiss.
A coolant system may leak from vacuum, but not pressure.
Or, visa versa.
26 is a lot either way, and you may have CAUSED a leak.
I would fill it with liquid and keep and eye on the level. It's normal for it go down a bit over the first few days as the system works out any air, but then it should stay consistent. If it doesn't check the head gasket or for a cracked cylinder head if not leaking from under the car.
Being a '94 I would just keep topping it up and driving it and not worry about it unless it's in mint shape..
Or, visa versa.
Agreed. Testing pressure should be operating pressure arond 12-15. Pumping to 26 psi could easily burst a radiator tube or gasket somewhere.
Nothing like acting first and getting proper procedure second. Great way to inflict damage to a vehicle system.
