Car is in question is my 08 Jetta. After moving I've been having to do alot of driving up and down mountain passes to get to work or shop. Thing is, when I go down, say 8% grade, my temp gauge goes from the normal (190) to almost the 120 mark. I still have the same amount of heat. I can only assume if the computer is reading a lower temp it's dumping more fuel. After leveling out the gauge will go back to the normal range. Coolant is right at the min mark, I've been thinking about adding a little more, but not sure. This has done this since I moved back to PA back in March, but now it's an everyday thing. Any guesses from you guys?
