If it is out of specs(too little clearance) and additional clearance is needed, why not? It really is not an adjustment. However, as the seat wears, the valve sets lower and the clearance decreases. If it gets out of specs, you either replace the valve (which you might have to remove stock anyway or you take off some stock from the old valve. I don't use a grinder because it is too easy to remove too much. Done it carefully on wet sand or an oil stone. Done it before with great results.I know know how you service Tecumseh valves and they are NOT ADJUSTABLE!!! I don't consider. removing a valve and grinding away the stem an adjustment
