TC-W3 Added to Fuel for DFI engine ?
PNW
Curious if there would be any benefit to adding TC-W3 to a gasoline Direct Fuel Injection Engine (DFI) for lube of the upper cylinder / combustion chamber ? For a ported injector gasoline engine the benefits of TC-W3 have been previously noted - Comments ?
Might help lubricate the pump & injectors but it will do nothing for the UCL - it never sees the backside of the valves before it's burned.
Thanks Scurvy - that is what I thought would take place . More limited benefit versus using TC-W3 in an EFI engine .
