Okay so here's the deal. This tapping noise started very faintly back in the winter but i never thought anything of it. Since then it's been getting worse and i would like to get to the bottom of it. I believe it's something in the valvetrain, either a lifter or rocker, somewhere in that area. It's not a knock, more like just a tapping noise. I can faintly feel it in the gas pedal, and if i put my finger on the passenger side valve cover i can feel it also. It changes with RPM, and at idle it's barely noticeable. If i rev the engine while parked you can't hear it, and if i let off the gas while driving it pretty much goes away. It seems to only occur in gear, whether it be driving or backing out of my driveway.
When you start the truck in the morning it sounds great, and when you put it in gear and drive off it sounds good. You can start to hear it after about twelve blocks. The truck has never been beat on or run low on oil, and it has had mostly synthetic the last five years. I switched to yellow bottle just for the heck of it, but it never changed the noise. My friend wants me to run seafoam through the oil but im very hesitant on putting a solvent in my crankcase. He thinks it's a stuck lifter. Another person thought it might be a loose rocker arm. If i drive the truck when it's warm and heat the oil up to temp, sometimes it will go away completely. It's just really weird.
Any help is appreciated.
-Colin
-Colin
