MolaKule
Staff member
Originally Posted by SpectroScientific
Background
TOTAL ACID NUMBER
A high concentration of acidic compounds in a lubricant can lead to corrosion
of machine parts and clogged oil filters due to the formation of varnish and
sludge. When a lubricant breaks down, acidic by-products will be formed from
the chemical decomposition of the base stock and additives in the presence of
air and heat. Total Acid Number (TAN) is a measure of acid concentration present
in a lubricant. The acid concentration of a lubricant depends on the presence of
additive package, acidic contamination, and oxidation by-products. Occasionally,
the depletion of an additive package may cause an initial decrease in TAN
of fresh oil. However, the accumulation of oxidation by-products and acidic
contaminants in an oil over time will always lead to an increase in TAN. This test
is most meaningful in industrial machinery applications although sometimes it is
recommended in engine applications along with Total Base Number (TBN).
TOTAL BASE NUMBER
Total Base Number (TBN) is a measure of alkaline concentration present in a
lubricant. Engine oils are formulated with alkaline additives in order to combat
the build-up of acids in a lubricant as it breaks down. The TBN level in a lubricant
is targeted for its application. Gasoline engine oils are typically formulated with
starting TBN around 5-10 mg KOH/g whereas diesel engine oils tend to be higher
(15-30 mg KOH/g) due to the more severe operating conditions. Specialized
applications, such as marine engines, may require >30 mg KOH/g. As the oil
remains in service, this BN additive is depleted. Once the alkaline additives are
depleted beyond a certain limit the lubricant no longer performs its function, and
the engine is at risk of corrosion, sludge, and varnish. At this point it is necessary
to top-off or change the oil...
See TAN and TBN Instrumentation and more info here:
http://cdn2.hubspot.net/hubfs/857680/WP_MeasuringTANandTBN_in_Oil_final.pdf
Background
TOTAL ACID NUMBER
TOTAL BASE NUMBER
