Tacoma lubes questions
bulwnkl and bbtaco are correct for the atf. have at least 5 quarts on hand (dex III or compatible syn atf) to be on the safe side if you plan on just dumping the fluid. if you want to do a exchange or flush you'll need more, 15 is what most people say. my 4runner dumped a little over 4 qts and was somewhat surprised also when i got that much out the first time. the 4runner and taco guys got the same after i did some research on other forums and is quite easy to do if you want to save some cash. make sure to check and or change the washer/gasket on the plug also and follow a routine schedule and you'll get many miles from your taco. fwiw i use just reg dex III (ace hardware brand (who makes that?)) and it is silky smooth.
regards,mudd
Yep 4-5 qts on a drain and refill of that transmission. Dex II or III is good for 02 and prior Tacomas. With such easy drain and refills (easier than the motor oil) there is no reason not to do it regularly. I am considering putting a sure drain on mine to save the aluminum threads on the transmission pan.
quote:
Originally posted by jsharp:
quote:
Originally posted by Bryanccfshr:
quote:
Originally posted by Steve S:
Chevron Delo gear oil works great and in you run in deep water do you modify your breather in the diffs. to run above water .
I run extended breathers but that does not garauntee that water won't make it's way past the axle seals.
I've heard this but the only time I've ever seen it happen with good axle seals was when the breather was plugged...
I just changed my rear diff after two years of use the coastal came out looking brand new. Unlike the factory break in lube that was knalry looking gear lube when it came out (pre-extended breather)When I get through my stock of Coastal gear lube I will go to synthetic as contamination seems to be a non issue for me. Maybe if I find some money lying around I can regear to get some performance back first
quote:
Originally posted by RickC:
Hi i'm new guy.
I have an '02 Tacoma 4x4 auto transmission w/37,000 miles. Everything up to this point has been dealership oil changes/PM's. To my knowledge every oil change has been with Citgo Superguard 5w30. Now I'm planning to go with this on my next PM:
Engine oil/filter: Mobil 1 5w30/Mobil 1 filter
ATF: Mobil 1 Synthetic
Transfer case: a GL-4 or GL-5 75w90 oil. Need help here!
Differential: owners manual says Hypoid gear oil GL-5
Front: 75w90, Rear: 90 Again need help here!
Once I have everything I'll take the truck to the dealership. Does the engine and transmission need a flush before adding the synthetics and if so should I request that to the service dept.? All suggestions please!
I have a 2002 V6 and im currently using amsoil 5w30, on my next oil change ill use 10W30. For the rear and front diff and xfer case amsoil server gear 75W90. For the transmission redline D4 (auto).
