I guess I don't understand. If the sump temp of a 20W-50 is hotter than a 10w30 under the same conditions, wouldn't this show the 20W-50 to be pulling more heat away from the crank, for example, and depositing it in the sump. If the 50 weight is hotter, what heated it up? Or is it not transfering its heat to the oil pan or oil cooler as efficiently as the 30 weight.
I think the phenomenon of lower sump temps with lighter viscosity oils is more the result of less internal friction within the oil itself and less the result of heat transfer properties.
Heat movement or heat transfer can only be possible if one body is cooler than another body, or if one body is hotter than another.
Place a hot slab of iron (300 F)on the left and call it SLAB A, another cold slab (0 F) on the right and call it SLAB B. Both Slabs have the same mass. Place a short round solid brass cylinder between the two slabs and heat will move from SLAB A to SLAB B until the slabs are at the same temperature, called "Equilibrium."
If the oil is cooler than say the bearing, heat will flow from the bearing to the oil. If the oil is hotter than the bearing, heat will flow back to the bearing. Hopefully, the oil will always be cooler than the bearing or say the piston.
The bulk oil temp is always higher than the coolant temp AFTER the engine gets to operating temperature. See this article in which a computer model of sump and oil temperatures was verified by dyno:
https://bobistheoilguy.com/forums/posts/196/
The oil has two primary heat sources:
1. Viscous Friction. Your engine is always putting some of its Hp into the oil by moving it, but the thicker oils require more energy to churn and to move, so some of oil's heating is due to the oil overcoming it's own internal friction, or "viscous" friction in the oil itself.
2. Engine parts, such as bearings, pistons, valve stems, and cylinder liners, contribute directly to the oil's heating by convection and conduction.
The oil's heat in turn is transferred by conduction, convection and radiation. The coolant takes most of the heat away from the oil. And some heat is rejected by the oil conducting its heat to the oil pan and in turn, the oil pan being cooled by air convection and by radiation. Very little heat from the oil is radiated.
[ March 11, 2004, 01:15 AM: Message edited by: MolaKule ]
