While my leakage experience is with gear oil, not motor oil, it will post it here anyway. Fact: 8-7/8 inch GM rear drive axle, 1994 vintage, not filled with synthetic lube at the factory, externally clean, dry and leak free at 40,000 miles. I changed the lube to Valvoline synthetic and the pinion seal started to seep right away, resulting in a oily, dirty and smelly axle housing. If synthetics dont cause leaks, what happened?
