OVERKILL
$100 Site Donor 2021
Originally Posted By: Clevy
I remember tearing in to my old 305 in my cutlass. The bores were worn and the cross hatching was long gone til the top of the stroke.
It was an 83 with 200k on it. The first 302 ford I tore into came from an f-150. It was a 94 and had over 400k miles on it. It was tired and we were putting a 351 in the truck.
The machine marks were still visible. I tore into a 4.6 2v from a 2000 mustang. I sprayed nitrous for over 100000kms and the engine had 300000kms total. Still had visible cross hatching. I've seen my buddies and their Honda's with significant abided miles on the engines and the cross hatching was still visible.
See my point.
So yeah they consume a bit of oil but the engines overall last longer before needing a significant amount of work and money.
Just my experience. Yours may vary.
You bring up something that has me pondering the squareness of the engines in question. While lower tension rings certainly have an impact on bore wear I also question, in the older engines, whether R/S ratio is a contributing factor as well. The 305 and 350 both ovalled their bores when the miles racked up and were far less oversquare than the little Ford 302 which had relatively tall pistons and a 3" stroke.
In fact I don't think I've ever seen a 302 or 289 with worn bores that didn't have some sort of mechanical issue
And that must certainly predate the adoption of the low-tension rings.
Of course modern examples like the Modular are square or undersquare and they still don't wear the bores. But they of course have coated skirts and low-tension rings.
I may of course also be over-thinking this, there is that possibility
See my point.
