Hi, wanted to know what you guys recommend for (or against) using a synthetic ATF in a 98 lexus es300. Any experiences? The 1998 calls dor Dexron type II or III. I was thinking Mobil 1 or redline (D4 ATF), or maybe Amsoils ATF. I believe the differential fluid is the same fluid sharing the same cavity as well.
Thanks in advance for your inputs!
