Originally Posted By: kschachn
Originally Posted By: y_p_w
There's really no real requirement for that. I thought that the requirement for a "single weight" oil is that it contain no VI improver. There's generally only minimum requirements.
Almost any 0W-30 motor oil could legally be sold as a 10W-30 because it meets all the requirements.
Royal Purple has SAE 30/40/50 listed on the API EOLCS directory.
https://engineoil.api.org/Directory/EolcsResultsDetail?accountId=-1&companyId=10239&resultsUrl=%2FDirectory%2FEolcsResults%3FaccountId%3D-1%26companyName%3Droyal
I didn't know about the RP oils, that's interesting. I don't know how that is accomplished to be honest.
Actually the API does require that even for oils without VII but which are non-Newtonian. If an oil meets the requirements for a 0W-30 then it cannot be marketed as a 10W-30.
Per J300:
Quote:
Most oils will meet the viscosity requirements of at least one of the W grades. Nevertheless, consistent with historic practice, any Newtonian oil may be labeled as a single-grade oil (either with or without a W). Oils which are formulated with polymeric viscosity index improvers for the purpose of making them multiviscosity-grade products are non-Newtonian and must be labeled with the appropriate multiviscosity grade (both W and high-temperature grade). Since each W grade is defined on the basis of maximum cranking and pumping viscosities as well as minimum kinematic viscosities at 100 °C, it is possible for an oil to satisfy the requirements of more than one W grade. In labeling either a W grade or a multiviscosity grade oil, only the lowest W grade satisfied may be referred to on the label. Thus, an oil meeting the requirements for SAE grades 10W, 15W, 20W, 25W, and 30 must be referred to as an SAE 10W-30 grade only.
It seems kind of strange, but their 50 seems to be fairly similar to their 20W-50 in terms of viscosities over warm temperatures and the VI.
http://www.royalpurpleconsumer.com/wp-content/uploads/PS_API_MotorOIl.pdf
However, the one thing that looks a bit different is that their straight weight oils are only certified to API SJ. I guess they could do things with it that they wouldn't be able to do with a multi-vis oil for the latest spec.
