Switching to M1 0w-40 in my BMW m3
AL
I've been running Mobil 1 5w30 in my civic for 3yrs and m3 for a year . I've read that M1 5w30 is not a BMW approved oil and that it runs on the thin side of a 30 weight oil. I live in Mobile Alabama were we don't have really cold winters were a 0 weight oil would be needed but I've had a few people tell me about the 0w-40 and wanted to try it out. Just wanted a few opinion on if this oil is "better" then the 5w30 i've been using. Thanks.
Travis
You've been running Mobil 1 5w30 in a M3? What year and have you had a oil analysis sample? I'd use Mobil 1 0w-40, Amsoil 5w-40 or Mobil 1 15w-50 in the M3 probably. What does the manual call for?
The car is a 95 m3 with a current 86k on the clock. I put 6k miles on it this past year with one 7qt fill of M1 5w30. I've never had a oil analysis done. As a matter a fact up untill recenty I never knew such a thing existed. I just bought 7qts of M1 0w-40 and am waiting to try it.
I also have another question maybe someone can answer for me. I only put 6k on the car over a year span. 6k isn't alot of miles but the fact that it's been in the car for a year does that mean it should be changed?
Well, it does depend on how it got those 6K. Lots of short trips are rough on the oil and then fuel gets in there as well unless you give it a nice long weekend drive. Unless you are running a by-pass system, 1 year seems to be the "safe" max limit.
Travis, my 2001 Passat 1.8T sees about 7K miles per year. I change my oil on a 3K mile / 6 month schedule. When I changed from 5w30 Castrol GTX to 5w30 Mobil 1 at 23K miles, I got timing chain clatter on hot idle. I dumped the Mobil 1 5w30 yesterday, after only a month and a few hundred miles and installed a larger oil filter and Mobil 1 0W-40. So far, no more clatter; we'll see what happens as the 0W-40 ages.
If I am right, Mobil 1 5w30 has no place in a hot-running modern engine, at least a turbo-charged one. My first impression of the 0W-40, however, is very positive.
Thanks for the info. The car rarely sees a round trip of more them 30-40 miles and most the time isn't driven more then 5 miles a day. The 6 month drain seems like it would work the best for me so I'm going to start that with my next oil change. I tend to agree with you now that M1 5w30 may not be a wise choice in this car but it seems to be fine in my honda.
Originally posted by Travis:
... I tend to agree with you now that M1 5w30 may not be a wise choice in this car but it seems to be fine in my honda.
I use 5w30 dino in my 4-cylinder 2003 Dodge Stratus, which gets driven closer to 10K miles per year. I use the same 3K / 6 mo schedule, almost always hitting the distance before timing out on the calendar.
Since you are in Mobile I would skip syn and just use Mobil Delvac 1300 15w40 all year. I use it in my Passat and it runs better than it did with the syns.
Does Delvac 1300 15w40 satisfy VW's warranty requirements? (I got one of the last 10 year / 100K mile powertrain warranties, and I don't want to blow it. VW is getting VERY particular in their oil specifications.) Even though I live in weather wimp land (coastal San Diego county), I am concerned about cold start engine wear.
I though about that but can't bring myself to do it. If you don't mind me asking, what part of AL are you from?
BMW is experiencing frequent engine failures due to customers not using the M3-specific Castrol 10w-60. Basicly, the thing will blow when run on thin oils. Syntec 5w-50 is similar in composition to the Motorsport 10w-60, I'd use that. The awesome PTG V8 M3 uses it. (insert pic)
You're thinking of new m3s not mine. Mine is a 95
Travis, I currently live in Huntsville, but I grew up in Pascagoula and have been through Mobile many times. The Delvac 1300 gives better gas mileage than I got with GC and is really smooth and doesn't bog my engine. I also run it in my Honda van. It is an SL rated oil so it will work great in a gas motor. You only need synth for extreme cold, turbo's, or extended drains with many miles. The Delvac has a TBN of 12 and should work great for a 6k oil change. I tried the Mobil 0w-40 and it ran good until about 4200 miles where I noticed a rougher hot idle. It will work good for you but IMHO is over kill.
John, it doesn't have any VW spec's listed on it and I wouldn't use it if you have the 1.8 turbo. I would only use synth in that motor. I have the v6 and with 5k oci's the 15w40 is perfect.
Other choices....
1. Saab 0w30 (Hard to find - No longer imported)
2. German Castrol 0W-30. It is almost a 40 Weight and BMW LL-01 Certified.
3. Amsoil European Formula 5W-40.
4. Mobil 1 5W-40 Truck and SUV (Delvac 1 without the Boron).
5. Mobil Delvac 1 5W-40
Gene
Gene
M1 T&S shows around 40 ppms of Boron in its VOAs and UOAs. New UOAs of Delvac 1 from the Diesel section also show 40 ppm of Boron. This lead me to believe that they are the exact same oil. Some point to a VOA of Delvac 1 with some 150 ppm of Boron, but that is really a VOA for CH-4 Delvac 1. I don't believe we have a VOA on this board for CI-4 rated Delvac 1.
Gene
Some of the latest UOA's of M1 T&S show 0 Boron.
I think Mobil has started to monkey with the D1 formula that was originally in T&S...
Gene
Whoa...I don't think so. The 10-60 is a totally different animal than Syntec 5-50 from my experience...
I am talking about 6-cyl M3s. What does your manual say? You should look at the TSBs for your car before you put in the wrong oil.
If it's a 95, it should have the standard viscosity chart indicating every oil from a 5-20 to 20-50 as being acceptable depending on ambient temperature (as it should be based on).
Hi Travis,
I'd say you're safe with 1 yr/6k mi changes using Delo or D1300S, or 2 yr/20k mi changes on M1 0W-40, 5W-40 or 15W-50. Here's my 1+ yr/6,500 mi Mobil 1 15W-50 UOA with only a 4qt sump! It looked so good that I ran the oil for another 6+ mos/4,500 mi (A-Rx application) before dumping it. Both M1 0W-40 & 15W-50 meet ACEA "light duty" diesel specs, while 5W-40 meets the more severe ACEA "heavy duty" specs. All three oils are approved for current API & ACEA gasoline engine specs.
Saab's currently recommending 2 yrs/15k mi w/M1 0W-40 in their 6qt sump turbo engines. With a bigger 7qt sump & N/A engine, you'd be conservatively safe for 2 yrs/20k mi.
