Thumper_sr5
Thread starter
Thanks to everyone for the food for thought!
(but I do sleep good using Mobil 1 5w30)
Good point.quote:
Originally posted by Ray H:
The argument that "you get what you pay for" can just as validly be countered with, "a fool and his money are soon parted" - they're both overworked cliches that have little relevance to actual value.
Valvoline gets beat up on in the Forum, but sounds like it stands up to the Turbo pretty well.quote:
Originally posted by dagmando:
Every car/truck is different, but any Toyota or Honda is not worth the extras expense and can easily go 7.5K on dino without issues and outlast the ownership. I have an '86 SAAB Turbo that has 250K miles on with Valvoline Conventional 10w30 every 7.5K miles and it has the original turbo and the engine has never been opened. This is an oil cooled turbo too which is really hard on oil where the new SAAB's are water(coolant) cooled. It runs awesome. Take your bosses experiance, run it until 5K if still a bit worried and you will still end up selling it before you need a engine overhaul, which rarely even happens anymore.
Ya know...I'm going to start that with ny next change. Excellent idea, can't believe I never thought of recycling the filterquote:
Originally posted by TooSlick:
Landfills are full of millions of oil soaked, used oil filters leaching into groundwater supplies. I run my high capacity, Amsoil SDF filters for 12,000 miles between changes, then take them to the local quick lube to be recycled,after allowing them to drain completely.
I'd like to see everyone take the time to also recycle their used oil filters, regardless of what brand of oil they use ....Most Quick Lubes are glad to take them!
TS
Not really. Take your used oil and filters to an oil change location and the oil is recycled. Also consider that if I burn 500L worth of petroleum products (gas or diesel) during the 5000km usage of those 4L of oil, it pretty much becomes a non-issue IMHO.quote:
Originally posted by 1maniac:
I'm no "tree hugger" but while changing the oil and filter every 3months/3k miles may make some feel better this is also adding alot more waste oil to the environment.
Visual inspection of engine oil and coloration is not meaningful, imho. Many great oils will go dark virtually immediately and some stay golden a long time. It doesn't mean much. Smell and feel work better if you can't do an actual uoa.quote:
Originally posted by TC:
1Maniac: Bingo!!! Lot's of great, insightful info on this board, but also a few fallicies which refuse to die, such as the "3,000 mile" dino nonsense. The 1966 Chrysler Imperial called for 4K mi changes, yet API standards haven't somehow greatly improved oil longevity since then, and maybe even regressed..? My 2002 model car doesn't even visually dirty its oil until after 3K miles -- only at about 4K does it go from "dark honey" to "root beer." 3K changes for vehicles like this are a complete waste of time, money, and environmental resources.
