quote:
Originally posted by moribundman:
How can G12 be the same as Dexcool? Wouldn't have Audi/VW/Porsche had problems similar to GM?
If you'll go to the BASF website url that I provided, you'll see three "Glysantin" chemistries: G 30, G 33, and G 34. All three are DexCool-type OATs, approved for VW/Audit, Peugoet/Citroen, and GM respectively.
I think you'll see that except for their colors, chemically they're all pretty much the same thing.
Valvoline (Zerex) and and the trade organization of independent radiator shops recommend DexCool as the replacement for the VW/Audi coolant.
The problems GM is having with DexCool appear to me to be the result of bad designs on GM's part of their V-6 engines and lack of maintenance on the part of owners, not a problem with the chemistry. That's why VW/Audi aren't having problems.
Any of the OAT coolants should work fine *if* they are not allowed to run low on coolant and *if* cavitation is not an issue in the design.
That's the Achilles' heel of these OAT coolants - they do a bad job of recovery from cavitation. Once the protective barrier is broken a chain reaction of rust and additional damage can take place pretty quickly.
I tried the DexCool in an older Honda when it first came out and ran it 150,000 miles with no problems at all.
If you're not going to keep your system topped off, however, G 05 looks like a safer bet.
