SuperTech Synthetic Oils
Has anyone seen any discernable difference between the 3 ST full syn oils? (ST full syn, ST advanced formula full syn, ST High Mileage full syn)
I searched through the VOA/UOA and all 3 look very similar when looking at additive pkgs and even viscosity for same grade.
I need a good oil for ny portable generator for my RV and it calls for 5w30 or 10w30. I figured the ST high mileage full syn in 5w30 would be a good choice. Your thoughts???
don't have any regular use/OCI experience with them, and I know for a fact that a VOA will not tell you everything about that oil, so the similarities don't mean much.
but I love using the cheapest SuperTech motor oil (10w40 or 10w30) for engine break-in whenever I do a fresh rebuild, cost + I have some of the best end results, but that is my experience only, nothing more.
I am sure it is great oil, I just can't justify using it because of rebates or some deal I find on BITOG that always ends up being cheaper then even SuperTech.
Assuming this is a small engine RV generator I don't think the various add packs matter much for a small engine?
I agree with the 0W-40 choice if you need to start in very cold weather. Otherwise a 15W-40 is also a good choice for a small generator. However if you do want to stay in spec honestly any brand 5w-30 or 10w-30 will be fine.
If it calls for 5w30, then 0w30 or 0w40 synthetic oil are better. Especially, if it runs occasionally. Any API SP oil is enough. 5w30 or 10w40 are cheaper to make, but not the best. Generally, any 0w-xx oil needs a better fully synthetic base oil for the same rating of miles.
