supertech no. for ph2870a?
I don't think they have 2870 supertech at walmart. I checked that catalog book there and it doesn't list supertech for my VW which uses 2870. I use the STP 2870 which I suppose is the same company that makes supertech(champion?). The numbers should be same because the fram 4967 and supertech 4967 is same which I use on the camry.
I think that's one of the consolidated part #s. If the walmart part seems smaller than what you're used to it might be worth cutting both open and comparing media quantity.
If it helps you might find a cache at some store on clearance...
What does their parts book/computer say your car takes?
