SUPER TECH HM FULL SYN 5W30 VOA
In the shop
OIL ANALYSIS REPORT
UIN 066EE37
New Oil Unit No. New Engine Oil
Unit: Make Model Serial No. Capacity: Site
Compartment: Name New Oil Make Model Serial No.
Customer:
DIAGNOSIS New oil. Diagnosis not applicable.
ANALYST: Jon.Sowers
LEGEND
Severe Abnormal Caution Normal
Normal
DATE SAMPLED 20-Mar-18 DATE RECEIVED 30-Mar-18 DATE REPORTED 04-Apr-18 LAB NO. 42021139119 SIF NO.
TIME ON UNIT TIME ON OIL OIL BRAND OIL TYPE OIL GRADE OIL ADDED FILTER OIL CHANGED WO NUMBER
Hrs Hrs
018828
Super Tech Full Synthetic SAE 5W30
Not Provided
Metals (ppm)
Iron (Fe) Silicon (Si) 5 Sodium (Na) 5 Potassium (K) Magnesium (Mg) 483 Calcium (Ca) 1293 Barium (Ba) Viscosity (cSt 100C) 11.0 Viscosity (cSt 40C) 67.0 Physical / Chemical
Base Number (mgKOH/g) 7.7
This is Super Tech High Mileage Full Synthetic 5W30 btw
Enjoy
Looks good to me!
We have been seeing a lot of boron in d1G2 VOAs, which jibes with a post wemay made about boron-based dispersants being used to prevent magnesium-based detergents from interfering with the MoS2-ZDDP synergy. I think...
so can someone interpret this for me? I have been waiting on this result. Is it a decent oil?
Its no M1 but YES its serviceable oil
Looks like you left all your personal info in the OP. I would have deleted that out of there.
Originally Posted By: LeakySeals
826 Moly? 753 Zinc? Whoa thats smooth!
I think the Moly is only 73 and the Zinc is 826.....the 753 pertains to phosphorous...
Are these new blue containers of ST now made by Citgo?....I no longer see WPP on the container.
Im not.the best with smartphones :^)
I'll see if the mods can delete that out of there.
Sounds good, thank you sir
I have a 2004 nissan frontier with 130k.. Uses no oil or no leaks..currently using Quaker State Ultimate Durability synthetic... wondering if I should switch to this Super Tech High Mileage or wait till leaks/usage starts... splitting hairs i guess..
I have 2 5 quart jugs left of Quaker State Ultimate Durability 10w30 im fonna use up myself. $1.85 each courtesy of AAP clearance
Looks decent.
I was wondering about that myself.
