SUPER TECH 20w-50 synthetic motorcycle oil VOA
In the shop
Here is the Super Tech 20w50 motorcycle voa.
JASO MA2 standard is not very stringent at all. Its only real value is the friction test for wet clutches. Most modern oil would pass the test moly or not.
That being said, I would not try toyota factory fill oil in a wet clutch with its 200 ppm of moly.
I stashed some a few years ago from a sale. I'm going to use this on the next oil change in the ZRX 1200. Impressed with the makeup of this oil. M1 10w40 4T and 20w50 Vtwin have much higher moly and boron but otherwise the ST oils are somewhat similar in additive packages.
Moly ????????
less than 200 ppm of moly is nothing, non issue. Esepcially below 100 ppm, not even worth talking about.
now you get 400 - 700 ppm, now you are bordering to have clutch issues.
Pulled the trigger and this oil is in the ZRX1200 sump as of today. Looking forward to giving it the usual 5,000 mile OCI. Won't get there on miles til next riding season, though.
With that said in the above post, this oil is in the lower half of the range for a 50 grade in terms of initial viscosity. 10w40 SuperTech MC oil is nudging in within a half point of being a 50 grade, both observations based on the VOA's here on BITOG. My instinct based on a UOA of the 10w40 (sheared down, but was in a smaller displacement high rpm engine) is to go with a sample at 2,000 miles to see how well the 20w50 is holding up based on the 10w40 report.
