Sunsong hose disappointment
D60
Colo
I ordered this LF hose for a '98 Ram from Amazon. Perhaps it's a fake but it came in a Sunsong bag and is anyone really faking Sunsong?
The metal bracket has been crimped on backwards. If I orient it properly as shown:
...you get the hardline end at the caliper, and thus caliper connection at the frame:
I'm also unimpressed with the crimps as they're mashed and oval. In comparison the hose retention on the OEM hose is perfectly round. Sunsong bracket:
I've got a Brakebest coming from O'Reilly tomorrow. We'll see if it's any better.
@Trav
I sent off an email to tech@sunsongusa
Will be curious to see if they respond at all.
Also, has anyone ever tried to report such things to whatever alphabet agency oversees such things -- presumably the DOT? I wonder if it's technically permissible for the crimps to contact/crush/compress the hose as much as they do?
That's unfortunate. I doubt its fake. Decent chance you hose from oreilly will be sunsong as well so will be an interesting comparison.
I don't think so. I considered such but Brakebest uses a part number scheme similar to Raybestos/Dorman of **380541
Sunsong was 2201122
FURTHERMORE I had another incident on the rear of a '12 Ram which was 90% my stupidity but 10% I believe due to Sunsong being a different length than a Brakebest. IOW I've had one other opportunity to directly compare Brakebest and Sunsong and they were different.
It's not that relevant but that thread was here. It will also cause one to question my intelligence and competence:
Something is not right with that hose, I suspect it is possible someone returned a dud in the Sunsong bag. Does it have Sunsong printed on the hose?
My apologies! The Brakebest arriveth and it is Sunsong
Here's the Brakebest on the bottom. Note that the mounting bracket is oriented identically but the ends are mirrored
The crimps on the Brakebest are a million times better, will post pics later
My apologies! The Brakebest arriveth and it is SunsongView attachment 248619
Here's the Brakebest on the bottom. Note that the mounting bracket is oriented identically but the ends are mirroredView attachment 248620
Glad you got a good one! I was researching brake hoses for a 2002 Silverado and from what I found on that application pretty much all aftermarket, to include acdelco, was reboxed sunsong. GM Genuine was available as well but I decided not to pay extra for it.
  • Helpful
Reactions: D60
Hey, look at the positive side of the situation...returning the defective brake hose to Amazon will be a breeze! Glad that O'Reilly's came through for you.
