quote:
However, moribundman, the manuf. tire pressures aren't set for 'soft'. They're based on OEM wheel/tire combos and vehicle weight. Increasing psi's will decrease your traction (especially wet/rough road) and noise. Fuel economy gains will be minimal (after OEM recom) unless you have a different tire/wheel combo...and all at the expense of ride quality (on anything but smooth roads). But, to each his/her own.... [Cheers!]
Audi (other makers, too) themselves says, if you drive sporty, you should increase tire pressure. They also recommend increasing tire pressure before long distance high speed driving (Keeps the tire cooler). I've always run a few psi above recomendation. The footprint of the tire won't change enough to decrease traction noticeably. I mean, how much more traction could I need on a Quattro?
Anybody I know and who drives their car sporty increases tire pressure. The manufacturer's recommendation are based on a driver, a passenger, and a sack with groceries in the trunk. I got a nifty schematic under my gas flap. It shows how tire pressure should be adjusted depending on the number of occupants and cargo. I always run tire pressure that's close to the upper limit. Like someone else said, if I don't do that, the edges of my tires will be gone way too fast. Handling also improves with slightly increased tire pressure. And don't worry, I'm not anywhere near the 51 psi limit the tires have.
Audi recommends 32 psi for the OEM 205/55/16 tires. I run on 36-38 psi.
zoomzoom, I'm against putting wider tires on rims. I know places where that's illegal due to safety concerns. I've seen people force 225 tires on 205 rims, and the tire was deformed, its structural integrity most likely compromised. If anything, I'd at least suggest to not go more than 10 mm wider. For example don't go more than from 195 to 205. Tire pressure should change with size and type of tire, driving conditions, and driving habits.
Perfect tire pressure also depends on the tire itself. Some tires have stiffer sidewalls than others, and wear and handling can change dramatically depending on inflation. I had one Michelin tire that was so stiff, I could let the air out and drive around without noticing a thing. It wasn't even a run-flat tire! That tire should have mandated the use of a tire pressure monitoring system, but it didn't.
OEM maker will rather recommend lower tire pressure, but put crappy low resistance tires on the car. That Michelin Energy tire comes to mind. It's one of the worst tires I've experienced when braking hard.
[ February 26, 2004, 06:57 PM: Message edited by: moribundman ]
