Sudden strange (rod??) knock
Brampton, Ontario, Canada
Hi all,
I have noticed a low pitch sound kinda like knock during the first 2-3 minutes after cold Ontario morning start-up, not only that; the whole engine seems louder there is also some valve chatter. The car is Acura 3.2 CL type S, I got it in December with 98,000km (60,000mi). Immediatelly changed oil to PetroCanada semi-synthetic 5w30 and a cheap orange Fram (I know but 'twas to be a short OCI). Just recently 1000 km ago I changed it out with GC 0w30 and a supertech ST3593 Temps here are around 2-4 C or just under 38-40F so it is not that cold once the engine warms up I have to put my ear to the valve cover to hear ir purr. Could this be a sign of a rod going or is the combination of somewhat thicker oil, somewhat more restrictive/deffective filter and colder weather to blame for my noissy engine?
Shuld I flush it with Gunk or STP slovent type stuff to flush out restricted oil passages? Or try 5W-20 with say Purolator Premium Plus 14459, or Fram Tough Guard 3593A (this may be less restrictive)?
Should I worry at all? this is deffinitely louder than any othe car my family has ever had except for the 3.1 98 GrandAm my father had before.
I kinda wanna keep the beast nomarawhat
P.S. the car burns absolutely no oil and from what I can see trough oil fill it is spotless the oil cap is also clean, tail pipes dry and relativelly soot free.
I had a similar experience with a cheaper Baldwin filter-offering that mirrors the Motorcraft FL1A. When I took the chattery Baldwin off & replaced it with a Napa Gold, the problem disappeared. I think it had a faulty ADBV.
The sad part is I purchased 6 of those cheaper Baldwins online - plus three other model numbers for another vehicle. I sure hope the other 3 are not "junk" also. May get lucky with the other five I have that mirror the FL1A, but I sure don't have any confidence I will.
The money loss would not be that great.... think I paid around $3.25 apiece. No... I won't return them for an inspection (or) ship each individual filter back as they fail one-by-one.
I'll just try one more & if it does the same thing, I'll toss the remaining four in the garbage & never buy or recommend Baldwin again.
[ April 11, 2006, 02:53 PM: Message edited by: Triple_Se7en ]
Where are you getting Supertech filters in Canada? I thought that was the US Wal-Mart store brand....I'm in Ottawa, and when I go to W-M, the 'cheapie' filters are Honeywells for about $4.00 each....
i won't use baldwin again either...because of low initial restriction, and good filtration ,i now use
donaldson, k&n,wix these 3 have a intial restriction of 2psid @ 4gpm with donaldson having the lowest of 0.5 psid
