By the way whats the best way to get all the lube out ? I hate to take the whole differntial cover off , Where can I get some manual device to suck it out the filler hole ... Thanks , Larry B.
![dunno.gif](https://bobistheoilguy.com/forums/graemlins/dunno.gif)
I second that!!!quote:
Originally posted by Steve S:
Take the cover off ,the other way sucks.
YEP..Then spray out the housing with a fine cleasning oil...then seal and fill.quote:
More times than not, the leaking diff is caused by the pinion seal, not the pan gasket. I had my seal replaced twice, they ended up having to replace the driveshaft coupling with an updated design.quote:
Furthermore, I can not tell you how much it angers me when i drive behind someone with a leaking differential(ie you can see the wetness on the bottom of it caused by the oil)...due in part by them not chanmging thier gasket.
