I went to a drain & fill with MaxLife every 20k and it helped the cold performance of the transmission tremendously. But that’s the 4EAT, I’ve never done the CVT like you have. I’m on older, less bougie Subies than you
She had a 2006 that was bulletproof. Put about 250k on it. That transmission and those diffs liked fresh fluid every 30k or they'd start binding at low speed into parking spaces and such. Aside from the head gasket at 100k on that one, not one issue. Everything was original that wasn't a wear item (like brakes). I liked that car.I went to a drain & fill with MaxLife every 20k and it helped the cold performance of the transmission tremendously. But that’s the 4EAT, I’ve never done the CVT like you have. I’m on older, less bougie Subies than you![]()
Sounds like a wheel bearing. My dad had a chevy cavalier and it droned. Wheel bearing replaced and all was well.Drove the wife's 17 Forester with almost 103k miles yesterday on a short roadtrip. Hadn't driven it on the freeway in a couple months. Nothing abnormal until I got just over 60. Then a very subtle droning noise. Typically we barely have the radio going but the little one was napping all we had it off. You could barely hear it over the tire and road noise but it's a definite "swarm of bees sound" that doesn't change when hitting different concrete/asphalt/new/old sections of the highway. So my hunch is either a bearing starting to go or something in the drivetrain. Had it out just now to fill with gas and buy some new wipers driving 45 in town and didn't notice the sound. 65 seemed to be the sweetspot. Which I found weird, because other cars with bad bearings I've driven are OBVIOUS at a wide range of speeds. But it's a very soft swarm of bees/helicoptery sound. Tires are fine. Any have experience with these and have any advice? I'm guessing the dealer will charge 2-4 hours of labor if I have both done and that's the problem they find. Until then, I told my wife to slow down and take the nearest exit to a gas station if it becomes super obvious. And told her to check the hubs with some quick touching in case they're hot when she gets to work and gets home. She commutes admit 35 miles highway speeds each way. My gut is until it's louder or creating heat (nothing was warm after our drive yesterday) we can probably not worry too much until after Thanksgiving...maybe a winter break drop off when we'll both have some time off and not need two cars.
Thoughts or ideas on what it might be or any other thoughts or advice, too.
Thanks!
Yeah, I was 90% certain given the sound. But it was barely audible above the road noise. Service advisor said the tech didn't hear it when driving the car but it was obvious with his stethoscope near the bearing on the rack. My ears are amazing I guessSounds like a wheel bearing. My dad had a chevy cavalier and it droned. Wheel bearing replaced and all was well.
On the last one I did, it was cheaper to keep replacing aftermarket bearings under warranty than to also replace the backing plate. At least for a DIY situation.Parts took a while to arrive. Then one bearing and the backing plates arrived. And the next bearing randomly arrived in a different shipment. They seemed confused. So delayed the repair by a couple days. From what I've gathered the TSB I originally found had been updated and our car also required the backing plates replaced (I found a revised TSB). The service department knew so that's why they were more spendy. Moral of the story: sometimes the dealer is more expensive...but would an independent have replaced the backing plates? I don't know. I'm tempted to call and see, however. Parts were priced within a few bucks I could've purchased for, labor was about 4 hours. Seems reasonable to me. And it's SO QUIET now on the interstate. I think it was sneaking up on us and until the growling started didn't realize they were loud.
https://static.nhtsa.gov/odi/tsbs/2020/MC-10185064-0001.pdfHow much are these backing plates, ballpark?
Ok so for a 26704FJ002 I'm coming up with ~$83
Or buy an aftermarket SKF bearing for $100 with a 5/60k warranty and slather the opening with anti seize for easier removal next time.Ok so for a 26704FJ002 I'm coming up with ~$83
For a 26704FJ012 about the same.
I just keep hearing they're "expensive" and wasn't sure what constituted expensive.
The bearing 28473FL040 seems to be $165 for OEM
If you're in the backing plate years TSB range, read the TSB. I think it is worded that the warped backing plates can cause the howl? Critic linked it again. Check it. Could be a backing plate? At least worth the dealer knowing the backing plates weren't changed if your place only did the bearing.?!?I’m glad yours is fixed. I had a highly-thought-of but not Subaru-specific suspension shop replace one rear bearing, and the sound did not go away. Drove an hour+ to the closest indie Subaru shop, and they think it’s the “transfer bearing“ or whatever hangs off the rear of the transmission toward the driveshaft. repair involves transmission removal. Gulp. If I do the clutch “while the transmission is off” we’re nearing $3k. There’s another $1k in other work I wanted to do…maybe time to punt. When was it again that new-car prices were going to come back down to earth????
What year/model do you have?I should have noted that my Subaru is not in that TSB universe. I personally held a stethoscope to wheel bearings (after initial left-rear fix) and quiet there, of course, the backing plates might not howl on a lift. But the center diff was growling/howling. Maybe not the viscous unit itself, but there are several bearings in that tailpiece, I just wish it weren’t so.
The written inspection from the tech said originally diagnosed as wheel bearing but after replacement will drive and check for other drivetrain noise after bearing replacement. When I asked the service advisor, they said since we're over 100k odds start increasing other drivetrain parts can make similar noises. AWD vehicles...the expense and maintenance of two cars worth of drivetrain.I should have noted that my Subaru is not in that TSB universe. I personally held a stethoscope to wheel bearings (after initial left-rear fix) and quiet there, of course, the backing plates might not howl on a lift. But the center diff was growling/howling. Maybe not the viscous unit itself, but there are several bearings in that tailpiece, I just wish it weren’t so.
Tried this (2015 Forester) and they failed exactly after 5 years. Went OEM at the dealership, $378 out the door.Or buy an aftermarket SKF bearing for $100 with a 5/60k warranty and slather the opening with anti seize for easier removal next time.
07 OBXT manual 5-sp. stock engine, but modded suspension. i really want a more “adult” car, but don’t know what would keep the grin, while maybe being a more relaxed long-distance cruiser…oh, and affordable.What year/model do you have?
