Hello all! So I have a bit of an annoyance and hopefully this huge community of oil gurus can shed some light on a problem of mine.
Anyway.. I have a 2004 Subaru STi with 99k miles and for some reason the transmission is just utterly stubborn. More than the acceptable amount.
When I am at a stop (dead stop) I cannot get this thing in first gear quickly (i.e. First in line at green light). I have to push in clutch, wait probably 5 seconds, then it goes into gear. If I just try to put it in gear, I get met with strong resistance (like hitting a wall), but if I wait a few seconds it goes into gear. If I double clutch it just makes problem worse.
Now.. I have never, ever (ever) heard this transmission grind into gear. Not at low RPM, or high RPM, or even downshifting. Clutch is disengaging fully. No weird bearing squeals or abnormal noises.
I am wondering if possibly my oil (All Brand NEW Motul 300) is possibly too thin for my aging syncros. If I try replacing a quart of 300 with that Pennzoil Synchromesh would that be beneficial or horrible? IDK what oil was in it before, but it did same thing...
Do Motul 300 and Synchromesh play well together?? I have no idea? And I spend about 100 dollars for the good oil, so I don't want to ruin it.
Or is there something else wrong with my poor 6Mt? I tried the IWSTi community and apparently stumped them
Thank you all so much! Sorry for long post!
