i have a 02 legacy gt 5spd w/95k. earlier in the summer it started running vary bad. have no problem starting it. it starts and runs when cold. it is after it gets to operating temp is when the problems start. starting out on a small grade from a dead stop just easing the clutch out it will fall flat on its face. have to get the rpm's up for it to go and then it will jerk real bad. even driving it when cold you can tell it is not just rite. when warm the idle is low around 600rpm and can hear a miss. i put new napa belden wires on and it ran worse and that is when the light came on in the dash. had friend come over with his scanner and showed missfire on all 4 cylinders. i changed fuel filter, had fuel pressure checked, new subaru plug wires,ngk plug, swapped out the ecu and crank position sensor, coil,throttle position sensor no luck. it has been 3 months now and i need to get this fixed before the weather starts turning bad.
