Subaru in a airplane
Inkom, Idaho
10 years ago I installed a Subaru EA-81 in my experimental catagory aircraft, a Rans S-7 Courier. This engine was professionally converted for aircraft use by Stratus Inc., the fleet hours number in the tens of thousands, with many units in the field (or over it, as the case may be) with well over 1,000 hours of trouble free operation. My own is one of them, at 1215 hrs TT I have had zero problems, compression is as good as new, oil consumption is nil, and power is also as good as new. BUT, I recently cut a filter open for inspection and the engine appears to be "making metal", non-ferrous metal flakes were readily apparent in the folds of the filter.
The engine, due to its out -in-the -slipstream installation, cools very well, too well in fact perhaps. My oil temps are often only 140 degrees, sometimes as high as 165, but rarely. I have been using Castrol 20-50 and change it and the filter every 50 hours.
Question: Have I been using too thick an oil in the tight little Subaru, perhaps impairing proper crank lubrication? What viscosity oil would be suitable for this situation? I will soon (later today) be dropping the pan to inspect the crank bearings and hope to find out where the metal is coming from. I will also be getting the results of an oil analysis within a couple days.
Tom
