7317
Part Number: 51356
UPC Number: 765809513563
Principal Application: Acura (02-08), Chrysler Imports (92-06), Ford Probe (93-97), Honda (01-08), Infiniti/Nissan (96-08), Mazda (71-00), Mercury Villager (99-00), Mitsubishi (90-08), Saturn (04-07), Outboard Marine Engines, Various HD Equip.
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.402
Outer Diameter Top: 2.685
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=6/19
Burst Pressure-PSI: 363
Max Flow Rate: 9-11 GPM
Nominal Micron Rating: 19
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.475 2.173 0.233
2808
Part Number: 51334
UPC Number: 765809513341
Principal Application: Acura (88-05), Chevrolet (85-88), Dodge (91-96), Ford (88-96), Honda (72-05), Hyundai (89-08), Isuzu (85-04), Kia (01-08), Mercury (87-91), Mitsubishi (89-98), Subaru (87-08) Atlas-Copco, Case, John Deere, Kobelco, Komatsu, Kubota, Onan, Toro & Yanmar Diesel, Other
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.194
Outer Diameter Top: 3.252
Beta Ratio: 2/20=22/40
Burst Pressure-PSI: 280
Gasket Diameters
3593
Part Number: 51381
UPC Number: 765809513815
Principal Application: Chrysler (83-93), Eagle (89-93), Hyundai (86-89), Isuzu (81-85), Mahindra Tractors, Mazda (89-90), Mitsubishi (83-96), Renault (84-87)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.141
Outer Diameter Top: 3.660
By-Pass Valve Setting-PSI: 13-19
Burst Pressure-PSI: 275
Nominal Micron Rating: 25
Gasket Diameters
Attached 2.834 2.462 0.200 (bigger)
