Stumped: Toyota CV boot clamp
OK, hear me out.
This is my working theory:
The yellow line is the fulcrum point that cams the tail over, the blue line is the side of the notch that interfaces and locks over and onto the red line (they're both straight cut faces where the lines are drawn).
I think we can all agree this is a correct assumption.
But somehow I've got to get the end of the tail (purple line) under the two smaller tab guides (green line).
I think it is much simpler than you are making it out to be. If my interpretation is correct, your references to the purple line and green line are not pertinent. The clamp is pre-sized to fit the boot where folding the (blue line) groove over the (red line) bump will provide the correct amount of tension with a minor bit of adjustment possible. Then you bend the two upright ears down to capture the tailpiece.
This is it. The only purpose is for consistency and standardization during the assembly process at the factory. But IMO it's over engineering something simple. For the average rebuilder there's nothing wrong with the standard style clamp that you can use pliers to install without special tools.
I’ve done these. Factory set up. Could not be easier.
No special tools required, just a couple strong fingers to bend over the first part of the clamp, fold down the ears, and finish up by pushing hard with a tool to ensure it’s all flat.
Oetiker style clamps require special pliers.
These require nothing special.
I fumbled with those clamps during a recent CV reboot - when they work, they’re great. But then they don’t it’s frustrating. The gotcha is the kit includes identical clamps for the rubber dampener sleeve. I’ve destroyed a few and used “universal” pinch-type clamps.
