I am planning having new struts installed on my 94 Camry over the summer. How do I know if I should also replace the strut mounts? (165K miles). I assume strut mounts are also called strut plates and bearings?
Quote:
Well seeing it's a '94 with 156k miles in salt laden, NY, I would just replace the mounts now. If it's too much, at least replace the fronts. If you have a mount issue shortly later, you'll be paying the labor again to replace the mount anyway.
Quote:
I've wondered if one can take off the top nut from the strut and then remove the 3 nuts holding the mount to the car frame and be able to reach up and replace the mount without having to remove the strut assemble from the lower control arm?
