Originally Posted By: chevyboy14
Is there a way to do the mount without screwing the alignment up?
To replace the mount, no, but you could minimize the alignment change if you lock the brake and use a camber saver tool. The camber saver tool attaches either to the hub or brake rotor using a magnet or to a wheel stud using a set screw. It has two perpendicular bubble levels that can be adjusted to center. Center these before loosening the strut bolts. When you are ready to tighten the strut down, you just move whatever around slightly to make sure the levels still read center. The brakes must remain locked the whole time. Locking the brakes with a stick can cause the battery to run down unless you defeat the brake lights in some way or put a charger on the battery. If you do this your camber will be the same when you're done and as such your toe will be fairly close. Fairly close means you can drive it for a while, but you'll still need to get an alignment before too long to prevent excessive tire wear.
There is a way you can lube (not replace) the bearing portion of the strut mount without losing the alignment. Unfortunately, it is quite dangerous. If you lived just down the road I'd be willing to walk you through it, but to explain it on an Internet forum and hope you don't kill yourself would be irresponsible.
