STP S 10590 CUT OPEN
In the shop
Off of a friends 2017 Ford F-150 Lariat truck with 5.0 V-8 engine. Had this filter and Stp syn 5w30 for 5k. I put Magnatec 5w30 and XG 10575(FRAM ULTRA) in and on. Miles on trick is 48900 also
Yes, before everyone asks; this is made by Purolator and there are slices in ADBV.
Originally Posted by NoNameJoe
I guess call it a drain back valve? lol Do the cuts go deep?
Anti drainback valve so oil does not empty or leave the filter. Cuts werent deep also
Originally Posted by JohnnyJohnson
Adam are those small cuts in the ADBV? If so did they go all the way through?
Johnny yes they are. They didn't go all way thru
Originally Posted by BAJA_05
Looks fine to me for that mileage. Thanks for the multiple cut & posts tonite Adam.
Dale
You're welcome sir
I was joking that it was a drain back valve because I was saying if the cuts were deep, it would lead to oil draining out instead of what the anti-drain back valve is supposed to do (which is keep oil in).
That filter is missing some pleats near the seam. How hard can it be to make tight even pleating? Most cartridge filters do! Thanks for the C&P.
Oil looks nice and clean yet. I love those 5.0L Ford engines. Thanks for the C&P. I am going to switch over to a Fram Ultra filter on my 5.0 next oil change too.
