Another option (for those so inclined) is
Power Service Diesel Lube Oil Extender.. It provides a healthy dose of ZDP (3357 ppm) with without VI Improvers (thickeners).
There is also a VOA posted by
nickmckinney
Power service Diesel Lube Oil Extender VOA
I first noticed this product in Tractor Supply and then found some discussion about it here in the forums. I requested an MSDS from PS and it looked like it might be a good source of ZDP with out VI improvers so I sent an email to Power Service asking if their Diesel Lube Oil Extender contained VI Improvers. Their reply is as follows:
"Diesel Lube Oil Extender does not contain any thickeners to affect the
Viscosity Improvers of the oil. It will not affect the base of the oil
either. It only affects the detergent package of the oil. This is why
our product will not void engine warranties. It does an excellent job of
dispersing the soot in the oil which reduces sludge formations. It will
stabilize engine oil, reduce foaming, oxidation and help neutralize
acids.
I have attached a spread sheet showing all the tests that it has passed.
I don't know of another oil additive that has been put through these
strenuous tests and passed. Most oil additives will thicken the oil.
(Summary from the spreadsheet:
Tests: Caterpillar 1K Test, Detroit Diesel 6V92TA Test, Mack T-8 Test, GM 6.2L Test, Mack T-6 Test, Caterpillar 1N Test.
DL Oil Extender contains zinc which helps fill in or causes a molecular film to form over the cracks and imperfections of the combustion chamber (lower cylinder wall) which prevents cylinder from using oil. DL Oil Extender contains magnesium which is an excellent lube agent)
If you have any other questions or concerns please give me a call.
Best regards,
Brian Wilson
Technical Advisor
Compliance Coordinator
(800)643-9089
[email protected]
Power Service Products, Inc."
Also, Here is a snip from the MSDS that states PS DL oil extender contains ZDDP ...
"SECTION II - COMPOSITION/INFORMATION OF INGREDIENTS
INGREDIENT/PERCENT
ORGANIC DETERGENTS, DISPERSANTS AND CORROSIVE INHIBITORS/30-40
PARAFFINIC OIL/50-60
The composition of this mixture is proprietary information. Specific chemical information is being withheld as a Trade Secret. In the event of a medical emergency, compositional information will be provided to health professionals in accordance with 29 CFR 1910.1200.
This product is hazardous as defined in 29 CFR1010.1200, based on the following compositional information.
OSHA HAZARD/COMPONENT
Eye Irritant/
Zinc salt of dialkyl dithiophosphoric acid (ZDDP)"
