Removed at 98k oil change. Was put on between last dealer oil change at 89k and this oc at 98k. I expected to find it in worse condition given what fell out when I unscrewed the filter and after CEL was on in my friend’s car with 1 to 1.5 qt low on dipstick before I had chance to do the oil change. Was on very tight and used filter wrench to remove (causing dents to top of filter canister)
Examined pleats in sunlight and didn’t see anything abnormal. Will try and get plastic end caps off and photograph pleats spread out.
Anyone have an easy way to remove the plastic caps? Metal caps came off pretty quickly.
Here is link to new filter info on 2808xl on autozone
https://www.autozone.com/filters-an...p-extended-life-oil-filter-s2808xl/663639_0_0
