Originally Posted By: cryption
I run the gas out in mine, but store it with the oil from that season. I run a Synthetic oil in my mower so I'm not worried about it sitting until the next spring. It stays lubricated, and there isn't a chance of moisture building up over the winter because I'm going to throw fresh oil in it before I start it the first time. I would rather store it with the old oil and throw the fresh oil in at the beginning of the season.
Plus, it's part of my ritual. At the beginning of the season I change the oil and spark plug in all my equipment.
I don't fully understand the change-after-storage rationale which some people post.
You are concerned about moisture possibly being in the oil after storage. Let's assume that it's a fact that you WILL accumulate moisture over your storage season (just how long is the "winter" "storage" season in TX anyways?) for the purpose of discussion.
With the old oil in place you have all of the sulphur, nitrogen and wear metals in your oil. When that guaranteed moisture strikes now they form acids which are definitely in your oil all "winter". Then you put fresh oil in for the spring and start it up with no water.
With new oil in the crankcase, you have clean and fresh oil in place which picks up a little bit of moisture. No acids or other gunk forming. In the spring you start it up and there's some condensation in the oil. Is this enough condensation to interfere with splash lubrication? If not it will burn off pretty quickly in the air cooled OPE and you'll still be back to fresh, clean oil.
Which does the equipment more harm? A storage season with acid in the case or the possibility that there may be some reduced lubrication due to condensation which will burn off?
In case anyone couldn't tell
I'm a pre-storage oil changer in all applications (including road vehicles). I also store with fuel tank dry, although some of my OPE actually comes into my basement so it's as much about not having gasoline indoors as it is about storage regimen. I also fog the cylinders and run Amsoil AST stabilizer in all OPE fuel throughout the season.
