Girlfriends CR-V had worn out brake pads this fall and I changed the pads/rotors. Fast forward to January/February and the pads were shot on the rear right (complained of squealing brakes). Lots of material left on the rear left. I tried to press the piston back in and it was way harder than normal so I figured the caliper must be the issue. Changed the caliper and rotor on the rear right and put fresh pads and bled the entire brake system.
I then started to keep a close eye on her car since she's oblivious to burning brakes. The brakes were still sticking and smelling burnt if I'd go for a ride. Did a bit of reading, and found that a bad brake line could act as a check valve. Car had 90 000KM but figured what the heck, ordered a new brake line from Rock Auto for ~15$ .
I took the caliper off the carrier, slide pins are perfect (Sylglide) and pads are moving without issues, and still have anti-seize. Put everything back together and bled the rear right. Just came back from a brief drive, and still smelling like burnt brakes. I can feel the heat difference and noticeable smell which isn't present sticking my nose near the other rims... Rotors are Centric Premiums, and posi-quiet ceramic pads.
What gives? Anybody got any ideas? Should I just bring the car to Honda?
