status: Filter Element Efficiency Study
Just a quick set of notes, if you have credible data for me, PLEASE send it to me via e-mail, NOT PM.
My current process and conclusions:
1. It is sad that the companies that tout "Beta" the most legitimate method of comparison are the least willing to share it. Try this: "google" both "Beta Ratio" and a filter brand name. Count the hits. Then look for real data. You will be unpleasantly surprised. Counter to this is that those companies that barely mention Beta (or efficiency), e.g. Wix, have Beta Ratios prominently displayed on (nearly) all filter spec sheets. What do the others have to hide?
2. I have decided to remove hydraulic and other non-automotive filters from the study. Belatedly, I discovered that the non-automotive world finds automotive filter efficiencies to be a joke. Adding even one of the non-automotive filters would seriously skew the data, making the auto filters look very bad.
3. For a baseline set of data, I am using the "let us cut apart the filters and look at them" site http://home.mindspring.com/~ed_white/id7.html. It is definitely the best laid out, with the most readily usable data. I think that it also is the most comprehensive.
4. I am attempting to get data from the manufacturers for each of the branded filters in the site above. I will use the rating criteria as stated in that study, adding my findings to come up with a composite. As stated above, some companies respect their customers and provide Beta ratings. However, there are several that tout Beta as the only valid method but do not respect their customers and refuse to release the data.
5. The three factors (and weights) I will use are
a. filter efficiency for particulates < 15 microns, (50%)
b. filter efficiency for particulates >= 15 microns,(25%)
c. the rating from the site above (25%)
yes, I will normalize the data. Therefore, if any filter is tops in all category, it will have a rating of 100.
6. I am giving all companies until 30 October to provide customer-respecting data on Beta for < and >= 15 microns.
7. I do not know if I can "clear" the raw data by the legal staff mentioned in the other thread. If I can, then I will post it, to allow you to crunch your own numbers.
cheers!
cheers!
