I have a 98 Suzuki Sidekick 1.6L. I recently disconnected the battery to clean corrosion on the battery terminals and the wires. After using a file to remove the corrosion, I rubbed "bulb grease" on the terminals (The grease was dielectric grease made for electrical connections). Since then, the car has a very hard time starting. The battery power seems ok. The headlights turn on without the engine running. Once the car starts (finally) after trying to start the car for several seconds ("cranking"?), everything is ok until I turn off the engine. Any suggestions?
