Hey. Up again. Let me ask about that 2000 F-150 issue, the one where every now and again, it will grind on the starter, or that is what is sounds like. I appreciate the input as to how the timing on this 5.4 Triton ? engine is non-adjustable and if it was out of time it would run horribly... so, that brings us back to the starter, flywheel/flexplate, slash ring gear?? Let me first ask more about this ring gear and flywheel business, please educate me.. I was always under the impression, including from watching video walk-throughs on Youtube that a starter changeout consisted of two bolts, and lining up said starter, then wiring it. What all more is involved? And "shims"?? What?
And are we in agreement that even with a new starter, of unknown kind, that that may still be at issue in the truly intermittent nature of grind noise and no start when the key is turned? My S10 needs a starter too.. How does a starter become worn. ? Let us start there, I am not afraid of the work, but I do not know what is involved, and obviously the F150 is a little cleaner than the one that just got put back together and still won't start.
