- Joined
- Dec 29, 2023
- Messages
- 3
Hi all,
Regreasing my 2010 Subaru Outback 3.6r starter, since after 14 years the grease has hardened up. Since I'm in negative F temps a lot when I ski, I want to make sure I get something that will work at a wide temp range. Just planning on cleaning and lightly regreasing the planetary gears + bindex, and not trying to buy a $30 tube of grease I won't use again if possible (see exploded view)
What I can't figure out from reading is what grease would be best.
Options I've read:
- White Lithium ($13,16oz): Operating temp only down to 0c, so bad in the cold
- Moly ($8, 16oz): Heard it's too thick for this application
- Mobil Polyrex EM ($14, 14oz): Recommended for Japanese starters but confused if it's only for use in the electrical bearings, vs the gears of a starter turning over an engine
- Molykote 7514 ($32, 14oz): Recommended but seems overkill for something not used much
Is EM grease ok to use on the gears? Or should I just get some Mobil EP 2 grease (not sure if extreme pressure is even necessary other than wider operating temp)?
Am I overthinking this on a 14 year old starter? Yes
but thank you in advance for any advice!!
Options I've read:
