Originally Posted By: GumbyJarvis
I found this interesting, for those people who feel towing in hot climates has no impact on oil, or their engines, because the cooling and oiling system of their engine is more than capable of handling extreme heat even with thinner oils. Toyota and Mobil suggest bumping up a grade. Mobil does use words like "may" I guess that helps cover their butts.
Question:
Is 0W-20 Motor Oil Suitable for Use in Hot Climates
Okay, I am having trouble believing that 0W-20 oil is thick enough for the Florida heat (in summer). I have a new Tacoma. I have no problem with the 0W part (cold starting) that seems good but 20 weight in the heat of summer does not seem to be enough. Even the manual says if you are towing or going at excessively high speeds, it might be necessary to use a higher viscosity oil. Please help me get to the truth. I do not want to have what I would consider premature wear due to CAFE standards needing to be met, I am all for gas mileage but I am not willing to sacrifice the life of my engine for an extra 146.00 dollars in gas savings over a hundred thousand miles!!!! I will and have always changed my own oil, and Mobil 1 has been my brand ever since I worked at a gas station for my first job as a teenager. But I need some clarification on this 0W-20 weight, I do believe 5w30 is better suited to the Florida climate, especially when you consider the fact that I tow a boat at least once a week.
-- Gary Gilmore, Panama, FL
Answer:
Mobil 1 0W-20 is certainly robust enough to handle the climate in Florida, but considering there is additional towing involved, Mobil 1 5w30 can provide the extra viscosity you may need when towing.
Why with my truck, and Florida summers If I knew it was gonna be a summer of towing (has been many times) I normally put in 0w30 Rotella HDEO over my normal fill of 5w/0w-20..
Personal preference.
There is absolutely nothing wrong with doing that either. There is no problem with matching the oil to the temps and conditions the vehicle is going to be used under. It has been done that way for decades before CAFE and one size fits all came into play.
Question:
Answer:
