So I left my car set for a few weeks and came back to a humming sound. Tires are (newish) and recently aligned. I just drive 300 miles across Ohio and noticed a humming sound from the front. I’m thinking wheel bearing? I also noticed while doing brakes last spring that my 21 Altima has staked axle nuts. I don’t have a factory tool to remove the nut, if it is in fact a wheel bearing. Any helpful hint on not destroying the axle? The hum starts at 60-70 and is gone by 80 and nothing before then. I’ll rotate a tire at a time to rule out my turanzas that only have around 20k on them but still have 8/32nds. There’s no heating up of the rotors so I’m sure it’s not a hung up brake pad.
