spots in transmission fluid*
New York,Ny,USA
Hello Guys, I just changed my transmission fluid and filters not to long ago.It been about a week since I changed it and today when I checked the fluid through the dipstick it had like little spots floating in the fluid. Not many and you really need to focus on it to see it because its so small. I did many reinsertions and pulled out ans I at least could spot two. I made sure it wasn't anything on the dipstick so I wiped it clean looked at it an reinserted again. I did not see this when I first checked the fluid about a week ago. The spots are like a white or gray color, I'm thinking it might be some dirt or sometime of lint from another rag I had. So I changed the rag to check. Do you guys think this is something to be concerned about? If it was outside dirt wouldn't the filters pick it up?
Maybe the clean fluid is just doing a little cleaning.. I wouldnt worry much about it.
if you wiped it off on a white sheet of paper or paper towel would you be able to see it better?
