My old Acura Legend has a speedo cable sectioned in two pieces; meaning that the cable runs from the speedo head out to under the hood where there's a threaded coupling that connects the top to the bottom section.
The bottom section needed to be lubed but the cable can't be separated from the casing. I know what kind of product(s) to use on a cenventional speed cable where the cable can be removed from the casing. However, I'm at a loss as to what will work for a speedo cable assembly that can't be separated into the cable and casing. How does one get the lube down into the cable assembly?
I tried the cable lube clamp I use for my motorcycle cables and it works pretty well as I can flush (with Berryman B-12) and dry (with a canned air duster). The lube that I use for control cables will not work for speedo cables though.....I know because the cable lasted 87 miles before it snapped.
Prior to spraying in the control cable lube, I tried to using a can of white lithium grease, but the can pressure is too low to force the grease down into the cable. It did build up enough residual pressure in the clamp to spray my face with grease when I disconnected the little red tube from the clamp.
I guess after flushing with solvent and drying, gravity lube method is seems to be the best way to go. Either liquid graphite or perhaps engine oil?
If the replacement cable comes already lubed, I'm home free. However if it doesn't, what would you guys recommend?
BTW, the replacement cable is $35 shipped...not too bad for OEM Honda.
Thanks!
Thanks!
