Speed Up Windows XP by 10%
...or install delete the C: drive, then install PC Linux 2008.
Have you guys ever had a problem installing Linux? The other day I was trying to install Ubuntu on an old Toshiba laptop with Celeron and It would neither load from the live disc nor it would install Linux.
Windows XP installs and runs without problem.
Tried both Ubuntu 8.04 and Ubuntu 7.10. It boots up to the initial menu from the CD but when I choose to either load or install it, it just sits there with a blinking cursor and reads from the CD for hours.
Download the alternate 32 or 64 bit Ubuntu .iso file from the following web site and burn a CD.
Link To Web Site
Install in the text mode and that should do the trick.
Link To Web Site
Installed the alternate Ubuntu. The laptop now runs much slower than Windows XP. So much for Linux being faster than Windows...
But what arch? i386?
Yes, it was 386.
Then download the i386 ver of Sabayon and give it a run, do you know what it has for a video card by chance?
Well, it is pretty well known (to Linux users) that the Gnome desktop environment is pretty hefty. "Linux" is just the OS, NOT the windowing environment. For older machines you should load Xubuntu which uses a less resource intensive windowing manager called XFCE.
XP has speed advantage due to the accelerated video drivers; a lightweight manager such as XFCE, Enlightenment or openbox on an older machine will definitely outperform XP since it consumes less resources.
OK, I'll give Sabayon and Xubuntu a try.
This is an old POS Toshiba Satellite 2595CDT which I don't know why I have kept for so long. Check out the specs
Intel Celeron 400MHz, 12.1” TFT, 64MB, 6.4bb HDD, Modem, CD-ROM
Windows 98 w/ dual linked Win95/98 Configuration Builder CD,
MEMORY: 64Mbit SDRAM, 3.3V (All models)
Standard 64 MB
Maximum 192 MB
VIDEO (All models)
Memory 2.5 MB integrated into chipset
Speed 50ns
Hyper Page mode support Yes
Controller Chip Trident Cyber 9525DVD
Data Bus Width 64-bit
AGP Local Bus (2D/3D) support Yes: 33/66MHz
Graphics Accelerator: Yes with 64-bit BitBLT support
In the Gnome desktop under Appearance Preferences shut off visual effects, that will help some.
In your case I too highly recommend Xubuntu.
Link to Xubuntu
Do the alternate install.
Another interesting distribution that will work and I use on a thumb drive when traveling is Puppy Linux. Very small footprint and could very well be what you would be looking for?
Link To Puppy Linux
Another distribution that should work well on older hardware is at @ the following web site.
I can't post a direct link to the web site because of filtering software but you can find it @ the following web site.
Link to Web Site.
The Linux Distribution is called (Censored) Small Linux.
Am sure you will find a distribution that will not only run quite fast on the older hardware but be useful too!
Many major book stores have some good books on these and other distributions of Linux.
