This is a followup to a past UOA: 60k ATF UOA
The car is a 2001 Saab 9-5 with an Aisin-Warner 4-speed automatic transmission. The owner's manual calls for a single drain/fill at 60k miles. As the UOA shows, the ATF was pretty shot by then, so I did 3 drain/fills with the Specialty Formulations Autoglide Dexron III ATF.
Now, 15k miles later (a total of 75k on the car) I've done another drain/fill with Redline D4. The results of the Blackstone UOA on the Autoglide are as follows (newest values are 1st column):
You can see the improvement in wear that the oil change brought. We're glad to see you changed this oil, since metals are still high. Wear should look even better in the next sample. Some of the wear metals that we found are residual from the last oil, as you can never get all of it out with a transmission fluid change. Aluminum didn't improve as much as we'd like, so we'll look for that to come down more next time. If it doesn't, the torque converter may not be wearing as well as it could be. The low viscosity and 0.1% insolubles may show excessive heat.
Quote:
-- 75k miles / 60k miles
Al 45 / 49
Cr 1 / 2
Fe 129 / 206
Cu 131 / 266
Pb 39 / 76
Sn 2 / 10
Mo 0 / 1
Ni 1 / 2
Mn 2 / 4
Ag 0 / 0
Ti 0 / 0
K 1 / 4
B 58 / 48
Si 31 / 56
Na 4 / 7
Ca 44 / 29
Mg 35 / 102
P 296 / 302
Zn 77 / 166
Ba 5 / 13
Sus Viscosity @ 210F: 41.8 (should be 43-49)
Insolubles: 0.1%
Next drain/fill is in 15k miles, so look for a followup in 2009
Al 45 / 49
Cr 1 / 2
Fe 129 / 206
Cu 131 / 266
Pb 39 / 76
Sn 2 / 10
Mo 0 / 1
Ni 1 / 2
Mn 2 / 4
Ag 0 / 0
Ti 0 / 0
K 1 / 4
B 58 / 48
Si 31 / 56
Na 4 / 7
Ca 44 / 29
Mg 35 / 102
P 296 / 302
Zn 77 / 166
Ba 5 / 13
Insolubles: 0.1%
